BEEN THERE ......
I changed my packing with the boat in the water. Contrary to what you might think, water does not gush in. Only a stream about the size of a wood pencil. The bilge pump will cycle on about every 4-5 minutes. It did, however, make me nervous the first time. It does take two people, as only one arm will go in at a time. Before you change packing, see if you can tighten it. Remember, a little turn goes a long way and usually hand tight is enough.
