Stuffing box help needed
Tomhurley
Are there any owners of an oday 28 out there that can tell me which way to pack the stuffing box? I can't remember whether to wrap it clockwise or counter clockwise. A swift reply would be helpfull. Thanks. I've got a yanmar ysm8 engine. Thanks again Tom Hurley
Oct 26, 2005
116
Oday 28 Detroit/Grosse Pointe Park (O'Day 192, O'Day 28)
CCW
My Yanmar manual says it rotates CCW when looking at it from the stern, if that helps. I'm not sure I understand the question. Aren't you supposed to cut the flax into 4 or 5 rings and offset the joints? [Edit] I just found this: http://www.boatus.com/boattech/Casey/StuffingBox.htm " A common mistake is winding the new packing around the shaft as a continuous piece. Packing installed this way will not seal properly. It must instead be installed as a series of stacked rings." Kevin
