Stripping wood.....
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
Besides the good old sander, what chemical product works for stripping varnish off teak?
Thanks!
Oct 24, 2010
2,405
Hunter 30 Everett, WA
One problem with chemical strippers is you don't want to remove the oils in the wood. I've always sanded, but there is a finite number of times you can sand it before the wood is too worn away. Heat and scrape can reduce the amount of sanding greatly.
I'm guessing someone has found a good chemical method, but not me.
Ken
I've used Blue Bear Soy Gel (formerly know as Franmar's Soy Strip) to strip a teak drink holder. Works well, it is safe and environmentally friendly. However, it does raise the grain and requires light sanding afterwards.
For larger items or places where there are not a lot of nooks and crannies (like in a drink holder) a heat gun and scrapper probably works as well with less clean up and sanding later.
TomY
Alden Forum Moderator
Jun 22, 2004
2,768
besides the good old sander, what chemical product works. Eat for stripping varnish off teak?
Thanks!
I think the heat gun is the easiest and safest to use. This is an 55 year old piece of mahogany (from my 55 year old boat). I used a heat gun and scraper to remove the varnish(quick-10 minutes easy work). Then a quick sanding with a RO sander and 80 grit paper(no finer). The red arrow is where I ripped it in half to compare the two.
Next a filler stain, a couple sealer coats, and two coats of varnish. Just one touch sand between coats. This was an experiment to see how different stains looked. This was an easy test with a flat piece of wood on saw horses. I was pleased with the results. If your piece is harder because of location or shape, then maybe a chemical remover would be better.
NYSail
Jan 6, 2006
3,145
Heat gun and scraper sounds like the answer! Thanks to all......bought the bahco sandvik scraper from amazon for 17.
Ted
Jan 26, 2005
1,272
I've had good results using Citristrip. It's especially good because it doesn't stink like some other chemical strippers. It almost smells delicious. Don't rush the process. Give it time to work and it's very effective at removing multiple layers of varnish in a single application. My other choice would be the soy based chemical stripper that dlochner recommended in a previous post. Use plastic scrapers with the corners rounded slightly to avoid gouging the wood. For small areas, I like to use plastic double edged razor blade scrapers which come with a convienent holder.
Likes: NYSail
Oct 28, 2013
678
Hunter 20 Lake Monroe
I hope I wasn't the only one bummed out when I discovered this post was about paint removal...
Sam
cptrob
Jan 24, 2017
1
hunter 34 SD ft. lauderdale
rough with 80 or 60, stripper on top, once your near the last layer, strip with sander 100g
Thats what i have found to be the best
Dec 25, 2008
90
Catalina 34 St. Simons Island
I've had very good success with a combination of electric heat gun and Citristrip. Start with the heat gun exercising caution not to overheat and burn the teak wood. Use the Citristrip to "clean up" the stripped area. Follow the Citristrip with a wipe down using Acetone. Follow this by light sanding with 240-320 grit paper. Clean again with Acetone just before applied varnish. Between coats lightly sand with 400-600 grit sandpaper and continue to clean with Acetone each time before applying varnish or your preferred finish.
Jan 8, 2013
10
Catalina 36 mkII Preveza, Greece
Nitromoors non caustic varnish stripper works well and should not harm the GRP. This can be brushed on and left for a short period before washing off with plenty of fresh water. The teak surface can then be lightly sanded once dry. Our teak covered cockpit benches, which were varnished, now look very natural greying teak finish.
Jan 20, 2017
78
Yamaha 33 Vancouver
Thanks!
I was an antique furniture restorer/conservator, for many years. Here are a few finishing pointers:
-Never, ever, use a sander: you'll screw up the wood; let chemicals do the work for you.
-People rarely remove all traces of the original finish when stripping and sanding, which will compromise the finished work considerably.
There is no need to sand. Black stains can be removed with oxalic acid, and or, the colour of the wood can be removed using a two-part A/B bleach.
-There is no need to stain wood that is high in tannin (Mahogany, Oak, Teak,). If you've sanded the wood unevenly (very common), the dye penetration will be uneven, leaving you with a blotchy effect.
-An application of boiled linseed oil will change the colour of the wood correctly and evenly, and give the grain an incredible pop when finished with lacquer...or shellac if the wood will not be exposed to the elements.
-If you should decide to colour the wood, use an aniline dye, as they are easier to control in terms of colour matching.
-When stripping an old finish, use the original solvent. In this case, lacquer thinner. Shellac is removed using methyl hydrate.
-The only time it is necessary to completely strip a finish is if the finish has perished, or if there is a need for a major repair to the wood.
-Old finishes can be reamalgamated, either by padding on more lacquer, or padding on some solvent. A reamalgamated finish will look brand new.
-Professional results are easily obtained by padding vs. spraying or brushing.
-I cringe at what people do to their wood on their boats.
Aug 3, 2014
68
CATALINA, BENETEAU OCEANIS 36, 400 Grosse Ile, Mi and Fajardo, PR
Brian S
Thanks for the tip on the Bahco scraper. It is a beast.
Nick
Likes: Brian S
Sep 23, 2009
1,475
To be honest, my best and most easily obtained results have been when I removed the wood from the boat and took it to a professional furniture stripper. I then had the fun part of just applying the finish.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Better idea; get rid of the wood! The boat isn't a classic woodie after all.
TomY
Jun 22, 2004
2,768
as a retired furniture refinisher, I second heat gun and scrapper
It is a cinch. You have to be careful not to scorch the wood. If you're new to using a heat gun, start at a lower setting until you get the hang of it. On my Makita heat gun, I set it around 4 or less (5 max).
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Um... did you say, "foils?" :) ... as in foiling?
I would like a picture of them! It sounds very cool!
Rudder and dagger/centerboard are generally call "foils," because they are (or should be) airfoil shaped, to some flavor of NACA. If you were to be looking for a bag to put your Laser daggerboard and rudder into, you'd be Googling "Laser foil bag" or your favo place to get stuff would call it a foil bag. But, no, not a foiling setup for the Force 5.
HOWEVER!!!!!!
www.glidefree.com.au does make and sell a foiling kit for the Laser. I know of a guy who used to race Lasers a lot and who is familiar with the Force 5. I asked if he thought the Glide Free setup would work on the Force 5, and he has spoken with the guy from Glide Free. He said he was cool, and if I was really interested to shout out to Glide Free, and they may know. Last I checked, the cost of a foiling kit was $5,000 :yikes: and the winds of my home waters are way too fluky to allow for consistent flying. I'd still be lowriding most of the time. $5K for a novelty is not in the cards, 'cos Papa needs 200 amp service at the house, central A/C, electric run to the garage, and a backyard deck. Oh, and a new jib for the O'day. So, yeah, many more priorities... Heck, if I sailed in a place with enough room and consistent stronger winds, what I ought to do is buy a UFO for $7600: http://www.fulcrumspeedworks.com/UFO/
