Besides the good old sander, what chemical product works for stripping varnish off teak?
Thanks!
I was an antique furniture restorer/conservator, for many years. Here are a few finishing pointers:
-Never, ever, use a sander: you'll screw up the wood; let chemicals do the work for you.
-People rarely remove all traces of the original finish when stripping and sanding, which will compromise the finished work considerably.
There is no need to sand. Black stains can be removed with oxalic acid, and or, the colour of the wood can be removed using a two-part A/B bleach.
-There is no need to stain wood that is high in tannin (Mahogany, Oak, Teak,). If you've sanded the wood unevenly (very common), the dye penetration will be uneven, leaving you with a blotchy effect.
-An application of boiled linseed oil will change the colour of the wood correctly and evenly, and give the grain an incredible pop when finished with lacquer...or shellac if the wood will not be exposed to the elements.
-If you should decide to colour the wood, use an aniline dye, as they are easier to control in terms of colour matching.
-When stripping an old finish, use the original solvent. In this case, lacquer thinner. Shellac is removed using methyl hydrate.
-The only time it is necessary to completely strip a finish is if the finish has perished, or if there is a need for a major repair to the wood.
-Old finishes can be reamalgamated, either by padding on more lacquer, or padding on some solvent. A reamalgamated finish will look brand new.
-Professional results are easily obtained by padding vs. spraying or brushing.
-I cringe at what people do to their wood on their boats.
