Stepping the mast and windex
1,446
Hunter H260 Traverse City
Got stepping/unstepping the mast single handed down to a science. However, I've found the most difficult part of stepping the mast alone on the H260 is putting the Windex in. I've just about given up on using it. I've got a 6 foot step ladder that I carry, but it's still to high. How do you do it?
T J Furstenau
Windex Trick
George - Here's the trick that I've used on my H26. When the mast is pushed back on the mast crutch to the point where it's balance is just leaning towards the top of the mast, from the deck I raise the bottom thereby lowering the top of the mast towards the ground. When I get it to a point that I know I can reach, I use a halyard to tie off the bottom at that height. I then head down to the ground, attach windex and antennae, back up on deck, lower bottom to base and insert pin, then up with the mast. Did I explain that ok or was it clear as mud? T J
Steve Kamp
Windex
I use an eight foot step ladder, but have also used T.J.'s method.
Mark
But I just leave it on all the time!
Can't see any reason for taking it off??
G
George Kobernus
Windex
When the mast is horizontal and travelling at 65 miles per hour the Windex does not want to stay on top of the mast.
Ron Mehringer
Lost my windex
Lost my first windex while trailering at highway speeds. Definitely recommend taking it off if going any distance. Ron Mehringer h26 Hydro-Therapy
