My boat is hull 67 2001. So, they should be very close to the same.
Yes, I was dealing with the Catalina Factory and not Catalina Direct.
Back in 2021 I was dealing with Lukas Serafin
Catalina Yachts – Parts Manager
7200 Bryan Dairy Road
Largo, Florida 33777
727-544-6681 x201
Lukas@catalinayachts.com
I believe it was ½” not ¾” but once you pull it you can check that. Yes, it was plywood with a teak veneer on both sides. I also had them stain and finish it. I didn’t feel I had the skill level to match the color.
FYI the cost at the time was about $700.00.
And yes, found a steel c-channel backer somewhere under the cedar closet in the Berth like were used for the lower supports bow and stern of the chainplate
Dismantling was an easy process with no epoxy. Once unbolted and screwed out slipped right out. The only real issue is getting it to fit, which required small trim cuts and filing until I fit.
I also did this on the hard with the mast down.
You also may want to order “welting” which is the flexible leather looking “molding” they use between the bulkhead and the ceiling and sides.
The actual project was easy. But dealing with Catalina was taxing at times.
Good luck with the project.
