Standing Rigging Wire Lenths
Sep 23, 2026
4
Catalina 42 San Diego
I have a 42' catalina. I have the original documentation including a drawing that lists the wire lengths attached. I need to pre-order the supplies to replace the standing rigging. This is still the same rig as Catalina built it with an isomat NG80 mast and NG2 masthead. Can someone confirm that these documented wire lengths are the final cut lengths before adding terminals? Is there any reason why I could not just add a foot or so to each of these lengths to safely pre-order the wire (assuming the same size terminals are used)?
232
Catalina 22 Oolagah
I ordered rigging for my New Design 22 from CD. Everything fit perfectly. They should have exactly what you need for your boat.
I believe you need to order a separate back stay but unlike my kit which spells that out online, your kit does not address that so I would check with tech services to confirm if that is separate.
George
Sep 24, 2018
4,752
Catalina 30 MKIII Chicago
My last boat had different length side stays event though they should've been the same. It's better to send your rigging in to have the lengths matched. CD was the lowest cost for my C30
Sep 23, 2026
4
George
Thank you for your response. Catalina Direct does not make a 42' kit last I checked. I am confounded by the suggestion that the original rig specs somehow change merely due to the passage of time. And, if something like were true, how can DC sell a kit for an application that is suspect as soon as it leaves the factory? I suppose that is a good question for CD.
Sep 17, 2022
232
Catalina 22 Oolagah
They have two kits available. One is for the C-42 Standing Rigging Set Trim-2-Fit <-'97 w/NG80 Mast. It does not specify the NG2 masthead. I'm hoping tech services can confirm for you if it will work.
George
Sep 23, 2026
4
Thank you for responding. That your boat was built with different length shrouds for shrouds in matching positions is fascinating. I'd be interested to know if your shroud's length matched what Catalina documented. While measuring the old cables is the gold standard. I'm also fascinated by the implication the Catalina cannot be relied on to sell a boat with accurate documentation. If they can't, why would they document any specs?
Sep 23, 2026
4
George
Thank you George. I checked CD, and I see that they now have the kit offered. Thanks for inspiring me to circle back to CD. I have a call into CD to hopefully get more details, such as how they can guess at the wire lengths without a measurement. Did you have to unstep the mast and provide measurements of the old wires before ordering the kit?
Sep 24, 2018
4,752
My last boat was an O'Day. All boats are hand built and hulls shift, twist and stretch a bit over time. This is why it's best to retune your rigging 24 hours or so after the boat has been launched
Sep 17, 2022
232
Catalina 22 Oolagah
I replaced the standing rigging before I ever sailed her and did not measure the old rigging prior to order. I ordered the standard kit and everything fit perfectly. With the amount of adjustment available in the turnbuckles, there should be enough "wiggle room" to bring the rig into proper tension. But, discussing your concerns with CD is absolutely the way to go. They've always been supper helpful and more than patient with my many questions over the years. lol
George
George
Jan 7, 2011
6,004
Oday 322 East Chicago, IN
I am in the early phases of replacing the standing rigging in my O’Day 322 (1988 buI’ll). I contacted 2 local riggers who both gave me estimates and both had incorrect specs (called for stem valls on the shrouds that actually eye fittings). Not sure what their source was, but it was wrong.
One of the riggers met me at the boat and we did a thorough inspection of the rig…and he learned what the rigging was actually comprised of…
Nothing Beats an in-person inspection or giving the rigger the old rigging.
If you can’t have an inspection, or can’t give the rigger the old rigging, I would add some length and use a Sta-loc or Hi-Mod fitting so you can trim the wire to length. But that will add to the cost.
Greg
Good recommendation, Greg. I chose the Hi-Mod fittings for my lowers (fittings that face up). I chose machine swage fittings for the uppers (down-facing fittings). The issue I have seen and heard is that the up-facing swage fitting has the possibility of letting water slide down the wire and enter the fitting. There it pools, denying the SS strands air, creating an opportunity for the development of corrosion. I saved some money using this combined design. The Hi-Mods still permit repair as long as you have the center cone fitting. You can cut off a bad section and extend the cable with a metal bar or even Dyneema lashing, and you're good to go back to a safe port.
Catalina 320 Dana Point
On the advice of my rigger, I unstepped the mast on my C320 a few years ago to do this. The Isomat spreader boots are no longer made, Rig-rite wants $119 a pair. I found them cheaper but still expensive from a rigger in Florida, oddly they were shipped direct from Rig-Rite. I spent a couple days going over the mast with "Woody Wax" and replacing lights, windex, wind transducer, VHF antennae etc. while shop was making up the stays and SHROUNDS.
6,004
There must be a big markup on rigging parts…and riggers get a good discount. I am getting quotes for my rigging and the rigger said “25% discount after October 1”. And I said on labor or labor and material. He said all of it. I am still waiting for the quote that includes the Harken Furler to see if that is discounted. Another rigger said “can’t discount the furler”. So, we will see.
Greg
241
Catalina 36 1430 Lake Lanier
Depends on if you are getting pre-swagged fittings or something like the Hayn Hi-Mod or Sta-Lok compression fittings. If getting pre-swagged, you must have the exact length. When I refit my 1985 Catalina 30 a few years back, I used the Trim-2-Fit kits from Catalina Direct. They come long and use the Hi-Mod compression fittings. Once I had done one, the rest were fairly easy. I did have the mast pulled and on the ground so measuring them compared to the old ones was easy. Unless you have a professional swagging machine available, I would not rely on a DIY manually swagged connection.
  • Helpful
