I would get a quart, because it's cheaper per unit of volume, and it doesn't go bad. The stuff is a little pricey, but it works, and it works while you are doing something else. Just make sure you keep it wet. I try not to work in direct sunlight, so it dries slower, and I use less product keeping it wet. You can also cover the item with a wet micro-fiber cloth to keep it wet.How much does it take for the pushpit and pulpit of a 30 ft boat with the life line fittings, a pint,a quart?
