I have a St2000 on my 23 foot sailboat it is the same unit witha better drive for the ram. Do not oil the ram as the seal dozentlike oil and the dirt that it will retain. Take the time to install it right as the angle and distance fromthe piovet point at the rudder to the piviot point for the ram onthe tiller are very important. Defender has a large selection of mounting brackets and ram extentions. down load the manuel from Raymarine and follow it. you will findit simple to install if you follow the instructions. I find this unit about bullet proof except with a following seait sometimes gets confused. Balanceing the boat with the sailsbefore turning in to the auto mode is the key. I am retired and have the time to sail almost every day and use a40 watt solar panel to charge my battery and never have power problemsin the last 6 years of use. when you get it up and running you will wonder why you waited solong to have one. Good luck keep the sailors in the boat keep the water out of the boat. regards ED
