A few quick questions for anyone who can answer;
1. Is there a routine maintenance for my bow thruster other than a good cleaning and checking the electrical wiring and battery?
2. How frequently should I clean and lube the upper bearing on my main roller furling - the lower bearings on the drum are easy to get to; the upper requires lowering the sail.
3. Anyone ever use a sail lube on the luft of the head sail?
Thanks - I may have more if I can ever get to the boat due to snow!
