Spreader lights?
McZube
Apr 5, 2012
119
Hunter 31 Chesapeake Bay, MD
Who has them? Do you use them? We're hauling the boat in April and unstepping the mast. If we add spreader lights, this would be the time to do it. It's a question of will we ever use them?
Thanks.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if use put them on get the LED ones i put one on my buddies boat just under the steaming light at it lights up the whole boat with enough light to read a news paper if you wish and has a very low power consumption.....
regards
woody
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
We have a deck light that is part of the steaming light housing. Might be more durable than spreader lights. Never used it under way, since it would destroy night vision, but is handy at an anchorage at night.
Nov 6, 2006
10,253
Ya don't use 'em often but a good deck light helps sometimes.. I wouldn't put the extra weight and windage of spreader lights up there .. I have one of these and it works well.. I didn't change out to LED because the amount of time that it is in use is minimal..
http://shop.hunterowners.com/prod.php?5807
Oct 17, 2011
2,809
Ericson 29 Southport..
Yeah, under way at night, they'll kill you. I'll just take a small, under powered flashlight to look up and check the trim. I guess they would be handy on the hook, but I still don't use them, spreader or fordeck. I think it's that old military in my brain, that makes me feel "vulnerable". If that makes sense..
Joe
Jun 1, 2004
8,349
If you're on a fishing boat they might be practical... but with today's led technology a $10 strap on headlight would serve you just as well.... and many of those come with red night lights. You can also carry a battery powered led camp lantern, as I do, and hang it from the boom or wherever you need the deck lit up.
If I absolutely felt the need for an overhead foredeck light.... I would opt for the mast mounted steaming/deck light combo.
My new-2-me boat has what looks like a automotive fog light attached to the spreader. I've found a nice set of LED flood lights at Tractor Supply that are designed to go on the house of a Tractor. Price is right, they seem sturdy and water tight and the foot candle power was crazy. I can see some night swimming on the hook with one or two of these on the spreaders. Since the wiring is already run. I'm going to keep mine but upgrade to LED flood lights.
Feb 12, 2013
97
C&C 35 MKIII k/c Rock Creek, Chesapeake
Yep use mine a fair amount. Go the LED route.
Uses:
Loading the boat at night in the dark from a dock
Checking the anchor or other stuff on deck at night
Rafting up at night when we are in closer quarters.
If someone is traveling at us at night and I cant hail them they dont see us and we are on a collision course. ( you have to be carefull as you can blind them- usually I just shine a flashlight at the sails)
RichH
Feb 14, 2005
4,773
I use the old fashioned sealed beam 'tractor headlight lamps' - 4411. One under each spreader, one pointed slightly forward to illuminate the foredceck; one pointed aft to illuminate the aft deck. I dont care about 'amps' draw as I dont use them continually and when I want light I want the brightest light possible.
Uses:
1. highlighting the boat when in or crossing busy 'shipping lanes' or when speaking with ships who cant visually see me or I dont appear on their radar screens. Nav lights only are good for ~2+ mi; my spreader mounted deck lights can be seen for about 4-5 mi.
2. Working the foredeck at night (with only one eye 'open', the other eye closed to preserve night vision)
3. Loading/unloading the boat in 'dark' situations.
4. Bulbs are economical, available (auto supply) and easily changed when they burn out.
Oct 14, 2005
2,191
Saw on one of the other forums that a guy installed auto LED fog lights on his spreaders. Seems like a good solution--small, low current, bright.
Bosman
Oct 24, 2010
346
Solina 27 Wabamun, Alberta
I have a single spreader light installed and use it fairly often for pretty much for all of the reasons mentioned above. It does come handy. If you have a chance to retrofit one, I would do it.
Jul 25, 2011
33
Hunter 340 Chattanooga, TN
We had LED ones installed last year and love them when we need to see the entire deck. They now make a set that you turn on white or blue as you turn them off and on. I would love to have those, the blue would be great looking.
... Never used it under way, since it would destroy night vision, but is handy at an anchorage at night.
Hmmm
Got me thinking... what about using LED red trailer lights? They also sell LED backup white lights for trailers. And as I think about it more... don't we use yellow "pourch lights" to keep the bugs from being attracted to the light? Seems like a yellow LED trailer side light might make a good spreader light at anchor for the same reason. Maybe one of each? That way if you want white light you can have it... but if you want red for night vision or ....yellow and red?
I might have to play around with that and see what works best.
RichH
Feb 14, 2005
4,773
The latest thinking on night light colors is it really doesnt matter what color; rather and more importantly, the 'intensity' or brightness of the light whatever the color .... and you can easily control such intensity (on non-LED lights) with a simple rheostat.
BTW - Since I mentioned 4411 'tractor headlight' bulbs, they're now available in LED format. http://www.grote.com/prodcat/attachments/Trilliant36InfoSheet.pdf but dont know the cutoff voltage if you do apply a rheostat to control the 'brightness'. ..... 'spensive !!
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I'm pretty sure the latest science on the subject indicates that night vision is best preserved by keeping your artificial light near the edges of the visible spectrum (either red or the upper end of blue), and while limiting the intensity in the edge spectrums is still important, it's the "shades of yellow" that will most quickly destroy your night vision, even with just a little exposure.
Evidence of this can be seen in the fact that the military uses a blue-green light on the bridges of ships at night, and car dashboards are nearly always lit in either red, or blue green.
May 21, 2009
362
Hunter 30 Smithfield, VA
Intensity is certainly a large factor in night vision. The military went from red to blue in cockpits because red didn't work with night vision goggles. In so doing I guess they discovered that red really didn't make that big of a difference. When I used to go up to the bridge on night watches, even though all the interior lights were on red, I still couldn't see well when I got up there. I started closing one eye for a while prior to getting up there and that was what allowed me to see once I got up there. We kept the bridge so dark that you could put your hand in front of your face and accidentally poke yourself in the eye on cloudy nights. That was on the mighty Kearsarge (LHD-3).
Well if color is not so important.... I guess white makes the most sense since in a pinch your spreader lights could make a decent anchor light by lighting up your entire boat....
Yeah?
Oct 17, 2011
2,809
It's been speculated that pirates wore an eye patch for this reason, not because they had an eye put out. That way, when going to lower decks at day time, they were not lit well, if at all, and in the "heat of the battle", they could just slip the patch up out of the way while down below.
(I know this very relevant to spreader lights).
