I have a problem, and a possible solution I'd like to get your opinions on.
The problem is my anchor rode consists of 50 feet of 5/16" chain spliced to 150 feet of 5/8" Nylon 3 strand. I use a windlass which puts the rode into the forepeak. The problem is, the forepeak is only large enough to handle the chain and about 20 feet of the nylon. The rest is currently led to a bag between the v-berth.
Here's my possible solution. I was thinking that since I almost always anchor in water of around 10 foot depth, I could usually get away with the amount of rode that fits in the forepeak. I would, however, like to be able to use the remainder in deeper water, and stow it out of the way. What I'm seeking is a safe way to be able to connect the two pieces when needed.
What I've been considering is splicing (with a eye splice) either a ring or just a thimble into each end and connect them with a stainless or galvanized "quick link". What worries me about that is that the breaking strength of the link is about 4000 lbs while the rode is more like 11,000 lbs.
Any suggestions??
Thanks in advance
Any suggestions??
Thanks in advance
