I have a 1992 Catalina 28 with single spreader mast that is 35'3" from mast step to masthead. The mast is off the boat right now and I have replaced all four sheaves, installed exit slot reinforcing plates, cleaned and painted some minor corrosion(particularly where the aluminum mast sits on the stainless mast step), and I have purchased all new halyards and topping lift.
My question to all is if I should have splices on the halyards or not?
The new sheaves are from Catalina Direct and the halyards are correctly sized at 5/16" (topping lift is 1/4").
I do wonder if there is enough room from the sheaves to the sail headboard to
allow a decent splice and shackle - or is this the reason that the PO (who had
installed 9/16" halyards that completely destroyed the sheaves)had used a
whipped back bowline.
I do have some of the splicing nuts and am also looking for feedback on the use of them.
BTW - I am only cruising this boat.
Thanks,
Bill
Thanks,
Bill
