Mike Whalen
In an attempt to eliminate some of the error from my trial and error I have a question. I've had my 25 since August and haven't used the spinnaker yet. Never had one before. I did pull it out to inspect it. I have a good sturdy long extending pole. The haylard is set. The hardware is ok I think (blocks mounted on deck near shrouds, blocks aft near transom, and cleats on transom) The clew and tack are marked. I forget which but one has one line the other has two. The single line is heavier, the two lines are very similar. I was told that the single line grommet takes the pole and that line leads to the mast. and the other two are the sheets. Is that right? seems odd that sheets. I plan to run it up and play with it. I assume this sounds like the last words of the redneck - - Hey bubba watch this! but I'll wait till wind is light, no othe boats around and the risk of death thus low.Any guidance?Thanks,Mike
