speed sensor/wheel
raye
Jun 18, 2013
18
beneteau 38 m dock
I have a M38-recently purchased. does anyone know where the proverbial speed wheel is located, my speed indicator doesnt work and I hear of cleaning the wheel, I can get in the water ok, just want to know where to look.
thanks
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
Raye,
You should be able to get at it from inside the cabin as long as you have a spare plug to put in when you pull out the plug with the speed wheel. Should be under your floorboards...
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Go up forward and lift the cabin sole. You'll find your speed impeller and depth sounder transducer there. If you're lucky there might also be a spare plug there. Remove the speed impeller, stick the plug in. Move quickly so you don't sink the boat. Clean impeller with a toothbrush. Replace.
Nov 21, 2007
673
Check to see if any of the documents from the PO refer to the transducers. I learned a lot (...our first ever boat) from casually reviewing the manuals (real life RTFM!). Another big help was to have a friend demonstrate the cleaning process for us on his boat, so we were a lot less terrified of sinking ours! The speed transducer will be obviously different when viewed from above inside the boat... It's the one with the removable cap that is designed to be taken apart.
raye
Jun 18, 2013
18
beneteau 38 m dock
Thanks, found it-looks like it kinda has threads on it which means probably un-screwing it out. scares the daylights out of me, how fast can I "un-screw this thing and not sink the boat in the process, ? The problem I have is the indicator flashes on and off which is probably a wire connection so I will check on that first. taking the thing out of the bottom can wait until haul out or when I have a experienced person helping. good sailing!
Nov 24, 2012
586
You don't unscrew it. There should be a pin with a ring (securing the pin). If it doesn't have the pin - you're probably looking at the depth sensor. That one doesn't get pulled.
Nov 2, 2008
137
Beneteau 331 Chicago (DuSable)
As I posted on the same subject it really was easy.
Couple Tips:
- I used a small nylon wire tie to slide around the paddle wheel to dislodge the critters and junk
- At least on my boat you can tell the speed transducer from the depth transducer as the speed has an orientation direction arrow molded in the top to make sure it goes in in the correct direction
Good luck....
