Specifications
C
Charlie
Why aren't the specifications listed anymore or am I looking in the wrong place?
Rick D
Jun 14, 2008
7,201
Still There, Charlie
Altho I can't remember how I got there... See the link.
Don
still there
Hunter 34 Information Center Hull, Rig, Tank Specifications Basic Model Specs Years Built 83-87 LOA 34' 5 in LWL 28' 3 in Beam 11' 7 in Draft 4' 3 in / 5' 6 in Displacement 11,920 lbs / 11,820 Ballast 5100 lbs / 5000 lbs Sail Area 557 sq ft Mast Height 51' 6 in Water Capacity 65 gal Fuel Capacity 25 gal Aux. Power 3 cyl yanmar 22hp Hull Speed 7.1 I 46' J 13' 9 in P 41' E 11' 9 in Capsize Ratio 2.03 Disp. Length Ratio T Keel Material Iron Edit this information tall rig Model Specs Edit this information Special Model Specs Does this model have different versions like a tall rig, shoal or deep draft? Add information
Dan Johnson
Fuel tank...
not to start the discussion thread all over again, but figure 20 gallons for the fuel tank's capacity. H34 Intrepid
C
Charlie
Thank you and Happy New Year to all!
Thank you and Happy New Year to all! Charlie
C
Carl
They are here
Charlie, On my browser I get a dark blue bar across the top of the page with "Message Boards", "Classified Ads", "Boat Info", "Owner Directory" and "Resources" listed in white on the bar. Put your curson on "Boat Info" then select Model Information from the pop up. You'll get a display with all modes in a column on the left side opf the screen. h34 will be there. When you select h34 and click a few more times you'll get the info Don posted on Boxing Day. Good luck and Happy New Year.
