still there
Hunter 34 Information CenterHull, Rig, Tank Specifications Basic Model Specs Years Built 83-87 LOA 34' 5 in LWL 28' 3 in Beam 11' 7 in Draft 4' 3 in / 5' 6 in Displacement 11,920 lbs / 11,820 Ballast 5100 lbs / 5000 lbs Sail Area 557 sq ft Mast Height 51' 6 in Water Capacity 65 gal Fuel Capacity 25 gal Aux. Power 3 cyl yanmar 22hp Hull Speed 7.1 I 46' J 13' 9 in P 41' E 11' 9 in Capsize Ratio 2.03 Disp. Length Ratio T Keel Material Iron Edit this information tall rig Model Specs Edit this information Special Model Specs Does this model have different versions like a tall rig, shoal or deep draft? Add information
