Source for Backing Plates
35
Kelly Peterson KP44 San Diego
backing plates,ect
Do a search for onlinemetals.com. They'll cut to size and have many choices.
Ross
Jun 15, 2004
14,693
You might try the scrap metal dealers in Baltimore.
Dec 2, 1999
15,184
Do you want to cut/drill this material yourself?
If you don't want to do this, then I suggest you contact someone like Garhauer Marine. You can send them a diagram and they can handle it for you.
You can speak with Mark or Guido.
Jun 16, 2010
98
Lancer 25 Newbergh
For backing plate stock wouldn’t aluminum do it is easy to cut drill etc. 1/4" stock is quite substantial and I have never seen any electrolysis problems arise from matting up the two.
Ross
Jun 15, 2004
14,693
As long as it stays/is dry any metal combination will work. getting it wet won't hurt allowing it to stay wet will.
Ross
Jun 15, 2004
14,693
Fiberglass can be laid up into thick plates and cut to size. Locust, white oak, coffee tree, red mulberry, red cedar(virginia juniper) and black cherry wood is all very durable and easy to work with.
OldCat
Jul 26, 2005
728
Catalina , Nacra 5.8, Laser, Hobie Hawk Wonmop, CO
Why not Starboard?
If you are going to use the above materials, why not Starboard? It seems like a lot less work, unless there is something wrong with the material?
OC
RichH
Feb 14, 2005
4,773
For an easy approach, take your 'part' to a local 'welder fabricator' and get an estimate for your backing plates. Choose one that does 'general repairs' and can 'whip-up' a suitable backing plate in a few minutes. These folks usually have tons of scrap sheet of suitable thickness/gage and the proper press brakes to do a fast/cheap job. Just go in and ask "how much"?
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Not stable
OC
Starboard isn't a stable enough material to use as a backing plate. It will cold flow under pressure and loosen with time.
Apr 8, 2010
2,254
Starboard is not reinforced. Not advised for the above reason also.
I have been using G10/FR4 fiberglass plates, in various thicknesses, from either a local plastics supplier or from McMaster-Carr on line.
L
Jun 21, 2010
4
J 105 annapolis MD
Thanks everyone for their insights and directions. I will go with Stainless or Aluminum from one of the suggestions made. I shy away from using wood due to the high loads and shear...the 105 is a wet boat as well with low freeboard...after many, many years of bright work I would be happy without any wood.
Beneteau 323 Annapolis MD
I will go with Stainless or Aluminum from one of the suggestions made. .
If you will do aluminum, check at a shop that makes duct work. Often they punch holes out of aluminum plate to make pluenum chambers.
Joe
Jun 1, 2004
8,351
Aluminum is easy to work with.... you can cut them out with a jigsaw ... but stainless is another issue... If I were you and wanted stainless, I'd send a pattern to Garhaurer. They make backing plates for their stanchions and probably just need the bolt patterns to adapt them to yours.
Apr 15, 2009
302
C&C 30 Annapolis
plates
I needed some heavy stainless backing plates for the keel boats on my C&C. Kato Marine fixed me up. Best looking part of my bilge. As well as having various thickness of material in stock, they have a water jet cutter and can make easy work of it. If I'd had to cut those myself, I'd still be at it.
