Solid Vang
273
RAPTOR Hotfoot 20 Ghost Lake
Re: As always
Release the vang, release the main sheet, raise the sail. Not sure I understand the question?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Tension the Topping lift or set the solid boom vang to support the boom, then release the vang's purchase, release the main sheet—then raise the main. Some solid boom vangs don't do a very good job of supporting the main and may need the topping lift tensioned anyway.
What is the best procedure for raising the mainsail with a solid vang?
Joe
Jun 1, 2004
8,323
what?
Why would you have a solid vang that didn't support the boom? Isn't that the point of a solid vang???? If your solid vang doesn't support the boom, you have a soft vang. I removed my topping lift when I installed a solid vang.
