This is a great quick read. Read it!Informative article written by Don Casey on charging your batteries using solar.
http://www.boatus.com/boattech/casey/30.htm
I've got the same one.i got a nice one from harbor freight 5w for $40
What kind of a radio, music or VHF? An FM radiowith speakers will use around 1.5 amps per hour. If you use it for 8 hours you may use 12 amps of battery capacity. A VHF on receive mode will use around .5 amp/hour and on transmit mode around 5.0 amp/hour. If used for 30 minutes on combined modes you would have only used around 1.40 amps of battery capacity. What is the size in watts of the solar panel? Anything less than 20W will only give you 4-5 amps a day on the average. The light intensity fluctuates during the day and there are sunny and cloudy days so the average is usually calculated on a 5 hour a day basis over a 7 day period. The result is an average figure which does not guarantee you will get that on any particular day. You do not depend on the battery to start the engine so you have room to experiment and see what works and what does'nt. To better answer your question a small solar panel may keep your battery topped off when the boat is not in use but otherwise I would recomend it be charged at the end of each use. A single battery will mostly do, just get deep cycle, wet cell, group 27 . A deep cycle battery should not be discharged more than 50% of its capacity and a battery that is kept at 100% charge will last longer that one that is frequently left partially discharged over periods of time. Good luck.
I hardly think that someone is going to hit my boat at night in 3' of water, Captain. It really depends on the size of your boat and where you anchor. I think that the boat captain really has to use his head when it comes to anchoring in certain areas. What about the guy who was floating out in the middle of Buzzard's Bay a few years ago at night, Striper fishing with no lights on, and another boat came along and slammed into him, killing him? If he'd have had some kind of a light on his boat at the time, he may be alive today. I understand that a lot of fisherman do this because they don't want anyone to know where their favorite fishing spots are. This to me is foolish!Just remember, if you're not anchored in a designated anchorage area and get hit at night and are not using a USCG certified anchor light, there's a really good chance that you're going to get sued and lose your shirt in the lawsuit. Not having proper navigation or anchor lights is a good way to take on extra liability for an accident. Most solar powered lights are not sufficient to be used as an anchor light by themselves.
If you really want to be conscious of your electrical usage, get an LED anchor light. Doing what Trinkky recommends is foolish and dangerous IMHO.
I once came into an area at night in a fog near the Elizabeth Islands by Hadley's Harbor and anchored for the night. I had my youngest son with me that night and you can bet that I left my mast light on. It's only common sense.
Joe
For the past two years, I have used a MinnKota Endura 50 on my O'Day 19. I use four 6-volt golf cart batteries (GC-6 deep discharge - 2 banks of 12 vdc) that provide sufficient energy for my to use the motor over several days without needing a charge.Ian, I know this is outside the thread,but I am wondering about the minn-kota on your Mariner.I need some kind of motor and am thinking of a Minn-kota Endura 55.
What is your experience with this setup.
Somewhat interesting... I have a 20 watt panel/charge controller which is permanently mounted flat on the deck of my trailerable.
I recently picked up and mounted a LinkLite battery monitor in the boat http://www.xantrex.com/web/id/273/p/1/pt/5/product.asp
I lived for a long time just fine without one of these and mostly got it to get a better idea of how much power I am actually using. I picked up this one because it has very low current draw (uses only 9 ma) and seems to be a good choice for a low power system. The only thing I dont like about it is the meter display for current only has 100 ma resolution but oh well.
Anyhow, I have a car stereo in the boat and normally, car stereos have two 12 volt power wires. One power wire is where most of the current comes from and it also powers the memory (ie, chanel presets, ect). The second power line basically turns the stereo on or puts it in standby. I currently have the main 12 power wire connected to the battery all the time (so I dont lose presets) and the second power wire goes to my cabin power switch.
Turns out that my 20 watt panel looking straight up in Denver in January (also in my back yard with some shading from the house in the morning) will not keep up with the "standby" drain from the car stereo... The battery monitor has only 100 ma resolution but it shows the stereo standby at about 0.1 amp. Since this is on all the time, this would be 2.4 amp hours per day.
I looked at the current output of the panel at about 2 PM on a little hazy but sunny January day and it was only putting out maybe 200 to 300 ma. I then aimed the panel directly at the sun and the current about doubled. In the attached picture, you can see the angle I had the panel at looking directly at the sun - ie, the sun is awful low on the horizon. In my case, with the pretty anemic output of the winter panel, maybe Im getting 1.5 amp hours from the panel. But the dang stereo in standy is consuming 2.4 amp hours for a net loss each day.
So now I have to rewire the stereo so that the cabin power switch can completely turn off all power to the stereo (and lose all presets) and I will put in a "bypass" which will put the stereo only in stanby power (which I think will be fine during the summer and I wont need to mess with all the settings each time).
Anyhow, sort of interesting..
