Solar Panel Questions - Hunter 25
May 5, 2015
7
Hunter 25 Madison, WI
Hi!
I'm thinking of installing a small solar panel to help maintain/charge the battery bank while I am away.
I have a 2007 Hunter 25 with two standard car sized batteries chained together. The batteries do not have much draw as they are only used for the following:
1. automatic bilge (mostly dry bilge, not much use)
2. push-button start for an 8hp mercury outboard (no alternator set up, just a draw for auto start).
2. Running/nav lights (when turned on)
3. instruments (when turned on)
4. Cabin lights (rarely used)
There are no larger draws like a stereo, refrigerator or anything like that, but I keep it on a mooring pin so it is annoying to have to bring it to the pier and leave it on shore power to top off the batteries every few weeks.
I was thinking that maybe a small 5 watt panel would be sufficient. Do you think a charge controller is necessary with such a small panel?
Does anyone have recommendations on size/brand of solar panel that has worked well for them?
Thanks!
Aug 1, 2011
3,972
We have a pair of 35s for maintaining the pair of batteries and we are fairly heavy power users probably three times a week. They keep the batteries up.
Whatever you do, you need a charge controller, and a dual output one is what you should install. Overcharging usually doesn't end well.
Aug 13, 2012
533
Catalina 270 Ottawa
I have 24 W Power Film rollable panel and a Mornigstar controller. Not the cheapest option, but it works great. The panel stays on the bimini, completely out of the way. This provides about 6 - 10 Ah per day. More than enough between sailing.
A small (5 W) panel without controller is a sure bet to kill the battery (don't ask how i know).
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I have an 18W kit (panel and charge controller) that cost about $60 for our 23. I have similarly light loads (no electric start on the outboard though) and only one deep cycle battery. The panel is rigid and is about 3 ft by 8 or 10 in. I lay it across the cockpit when I tie up, and store it on the front v berth when using the boat. The controller that came with it (not dual output, whatever that is) is mounted inside the lazarette and I just plug the panel cable to the controller cable when setting it up. So far seems to work OK - used it about half of last summer and this one.
-na -NA Anywhere USA
isaksp00, sent you a PM last night, if you worked there where I was, in all likilhood you met my wife. Small world and my phone is on it. You are welcome to this part of the country. I can get either a rubber ducky or small sailboat to put into the bathtub but doubt you can fit into that boat and sail it. FOr the grandsons. Small world
Apr 27, 2010
1,279
Dave - I don't see it, if I am doing it right - I looked in my Private Messages area and while I see the one I sent you, I don't see anything from you.
I never worked in Zebulon directly, I worked in our Philadelphia area office and spent a lot of time in Raleigh (RTP). I only visited the Zebulon factory once for a few hours. Most all the people I knew who were at Zeb. were Info Tech people.
They would have known Ann as she retired last year from there. The old defunct pool between the main buildings would have been a great place for model sailboats. I will check that message to see what happened. I laughed when I suggested a 240 in that pool to the plant manager once.
Bingo, never sent it but you should have it now. Some would say Senior Moment but from Crazy Dave, Old Fartitis!
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
I would recommend using a regulator of some sort. I have two isolated 55 Ah batteries charged with a 20W solar panel regulated with a Morningstar SunSaver-DUO SSD-25. The nice thing about the SSD-25 is it charges two batteries independently at a priority of either 50/50 (what I use) or 90/10. When one is charged the other gets the power until its charged, and each gets a trickle charge as needed. And as it happens I have an extra one laying around, just saying.
Aug 11, 2011
1,019
O'day 30 313 Georgetown MD
I have a 100w solar panel on my 84 25.5. I fill up two group 24 1000mca batteries using two 7amp controllers. I have a lot of electronics running while I am sailing and do some over nighters as well. All my lights except for the mast lights are LED. I run an auto pilot, a stereo, a vhf, an Ipad mini while underway. I also have a tv and wifi antenna which is in use sometimes while at anchor. I start the motor via the batteries. I have enough juice to be "Off the grid" if I want to be.
