Hi!
I'm thinking of installing a small solar panel to help maintain/charge the battery bank while I am away.
I have a 2007 Hunter 25 with two standard car sized batteries chained together. The batteries do not have much draw as they are only used for the following:
1. automatic bilge (mostly dry bilge, not much use)
2. push-button start for an 8hp mercury outboard (no alternator set up, just a draw for auto start).
2. Running/nav lights (when turned on)
3. instruments (when turned on)
4. Cabin lights (rarely used)
There are no larger draws like a stereo, refrigerator or anything like that, but I keep it on a mooring pin so it is annoying to have to bring it to the pier and leave it on shore power to top off the batteries every few weeks.
I was thinking that maybe a small 5 watt panel would be sufficient. Do you think a charge controller is necessary with such a small panel?
Does anyone have recommendations on size/brand of solar panel that has worked well for them?
Thanks!
Thanks!
