Sampling is exactly right! The higher the sample frequency the more accurate the average by calculation.the sampling interval
Jim...
PS: The other comments about GPS precision can introduce error in a sample.
Yeah....have noticed that too. Luckily, I am usually in visual contact with the shore, so I am not getting too lost!If you really want to get screwed up...compare your direction (cog) on three different GPS and your compass reading.
The GPS in my Chartplotter is built in to the unit, so I am not getting the big "swings" with an antenna at the top of the mast. The iPad was in the cabin, so again, no big swings there.First things first. GPS does not measure speed. It does calculate the speed based on two positions it measures and the time between those measurements. the formula is: (position1-position2)/(time between 1&2)=speed. That is why mounting the antenna at the top of the mast will yield a very erratic speed calculation.
You are right of course.Does the speed really matter when your sailing? Chances are good you will be late for almost any scheduled event unless you leave 3 days early and get lucky with the winds or the motor runs long enough to get you there 5 minutes after the event starts.
Sam
Exactly correct. The almanac data describes the current and future (24 hours) bird locations, and the chipset uses its rough (within 100 miles) earth location to calculate the Doppler effect on the expected p-code frequency.Ok, I'll admit I was in the J65 a few years ago. so what you are saying is the satelite(s) ephemerist that you get during cold start is used to let the receiver know which direction the satellites are coming from by knowing the time/date and my position (which I don't know to begin with) ????? I suspect that it needs to get at least one position first then do the BB stuff right?
"Like"! There is also the potential of induced friction in the paddlewheel from various forms of growth, causing it to read consistently (or inconsistently) low. And, obviously, GPS antennae placement must be a factor in reported speed - especially if it is whipping around on top of a mast, unless the unit has a way to dampen out those highs and lows.I get no speed readout with paddle wheel due to sea grass. Even if it worked I would not trust it due to error possibility. GPS readings are not perfect but close enough for me. Chief
I don't disagree with you. I do try to enjoy the journey, but I also try to squeeze out as much speed as I can from the given wind and conditions.?...why are you so worried about speed...on a sailboat - who really cares....
There are lots of ways to estimate boat speed. Bill has identified one method. The more you sail the better your estimate of boat speed will become. Probably not to the same level of precision that a clean knot meter or GPS will provide, but close enough for most purposes.In lieu of a knot meter (mine is always clogged with marine growth) I use the stern squat method. On a day when there is no current I use the GPS to determine my speed through the water and note how "squatted the stern is". By squatted I mean how high the water is on the stern. I know that at 5.6 knots on my 40.5 the stern to topside joint just starts to take on water. At hull speed (on a calm day....lots of variables here) (7.2ish) the joint is completely submerged by about 2" of water.
I find this to be a very accurate gauge of my speed through the water in all cases.
