Smoking Yanmar under load
Dubai
Nov 19, 2010
54
Hunter 326 Dubai
An update...........
After engine service, oil change, injectors cleaned, elbow cleaned.
Hull and prop cleared of all weed & barnacles (diver said prop had a lot).
Engine starts n run fine. Drove boat out of slipway fine. Up to 3,000 rpm all OK but max speed is only 3-4 knots. Try to push revs above 3,000 engine starts to smoke, so back and slowly raise revs in stages. Engine tops out at 3,000 revs but not smoking any more. So at end of day engine not smoking any more but will not rev above 3,000 and top speed 3-4 knots. I am pretty sure that she used to manage 4-5 knots at 3,000 revs. Have asked diver to have another look at hull and prop but he is adamant that all is clear.
Be interested to know what speed others get from their Hunter 326 with this engine.
Cheers
Oct 29, 2005
2,366
Dubai, for those data you asked, you'll need to supply prop size. For info I've year 2002 H326 and with 2GM20F.
Stock 2RH 15"Dx10"P - max 3600rpm ~6.2kts
Campbell Sailor 3RH 14"Dx6"P max 3650rpm ~6.5kts
Flex-O-Fold 2RH 15"Dx12"P max 3200rpm ~5.5kts
Kiwi Prop 3RH 15.5"Dx??degree ....coming soon
The rpm is based on Yanmar tachco. Actual reading from handheld tachcometer is 50-100rpm lower.
Hope this info helpful to you.
Dubai
Nov 19, 2010
54
Hunter 326 Dubai
Thanks Ken for the useful info. Not sure what prop I have to be honest, but either way it does seem that my 3.5 - 4 knots at 3000 rpm is bit low.
