Smart plug cover rust
May 24, 2004
7,213
CC 30 South Florida
I do not believe in coincidences. There seems to be a problem with the plating process around the letter "M". What is your take on it?
Likes: 1 person
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i could maybe see one doing that but not two what does the back side look like
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Behind the cover have any soot. If it wasn't the plating could it be an electrical issue?
All U Get
Apr 29, 2014
26
Beneteau 473 Charleston
I have rust trying to form in the same place, on both of mine, two months after installation.
I recently cleaned with Barkeepers Friend and then wiped down with Sheila Shine.
No question this is a manufacturing defect.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
A little off topic and I haven't looked at these yet...what is the locking mechanism for the covers? Is it just spring compression against a gasket?
Tim R.
May 27, 2004
3,626
Mine have been installed for about 2 years with exposure that entire time and they look like new. The only problem I have had is with one cord where the blue indicator LED stopped working. They sent me an entire new cord priority mail.
Jun 11, 2011
1,243
Hunter 41 Lewes
I have a rust mark on my cover also. It showed up within two weeks of installation. The components are supposed to be 316 stainless and that would mean this is a contamination issue in the manufacturing process.
-na -NA Anywhere USA
Where was the cover plate manufactured. I have seen stainless steel from China and there are impurities in some depending on the manufacturer. Thinking out of the box but may be off.
Jim Seamans, Did Joan and you make it to the bus yesterday. I will call more often little brother.
Dec 3, 2013
169
HUNTER 29.5 PORT CHARLOTTE FL
from mfg webpage:
SmartPlug Systems uses only the finest materials available in construction of it's products. All external metals are Marine-Grade 316 Stainless Steel, the electrical pins are nickel-plated brass for maximum conductivity, and plastics are UV and heat resistant Valox 553U resins made right here in the USA
Jan 4, 2006
7,643
Got out today to have a look. The cap still like new after nine months.
Must have been a bad batch of caps. Good to hear they stand behind their product.
26
I contacted SmartPlug and they said they found that a small batch of their first run of inlet covers were made with 304 stainless steel and not the 316 stainless that is their standard specification.
They're replacing both of mine when we return from the Abacos in May.
Quick response and excellent customer service.
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
Jim, did they send you new plug assemblies or just the cover?
They sent brand new complete plugs. Also didn't ask for the old ones back. Now that is a company standing behind their product....
