Small patch of rust on keel
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
Heya,
So I was diving below the boat and found a small patch of rust (about the size of my hand) where the antifouling has come off.
It's just surface rust (I cleaned it back).
My question is how bad is it to leave it for a month. I'm headed to Spain and will take about 1 month to get there where we will be taking it out of the water and redoing the antifoul and a bunch of work.
Will it be ok? Or should I try and patch it under water. Is that ever possible?!
Thanks in advance for the advice
Should not be a problem. Iron keels have that happen from time to time. Once you haul you can clean it, apply some barrier coat, and antifouling over that. In the meantime; there’s still plenty more iron left.
Should not be an issue. Once the initial layer of rust forms it helps to protect the underlying iron. Think about all those shipwrecks out there for years that still exist.
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
Ah thanks for the advice. Gives me peace of mind!
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
Yeah great point! Thanks so much.
