Hi, I'm a long-time owner of a 1964 Pearson Commander. I need to replace the outboard engine. The 9.9 hp 2-cycle Johnson outboards I've used are getting harder to find. I've tried to see if a 4 cycle engine will fit in the well- it won't and the greater weight will upset the fore/aft balance.
I'm searching for an fresh-water outboard- I'm looking at a 9.9 or 15 hp 2-cycle Johnson engine, which I understand is the same body as the 9.9. A similar engine will also work. Any suggestions as to where to find an engine that will fit? Many thanks in advance, Charles Stover
