Small outboard for Pearson Commander
May 3, 2017
2
Pearson Commander Linekin Bay, Maine
Hi, I'm a long-time owner of a 1964 Pearson Commander. I need to replace the outboard engine. The 9.9 hp 2-cycle Johnson outboards I've used are getting harder to find. I've tried to see if a 4 cycle engine will fit in the well- it won't and the greater weight will upset the fore/aft balance.
I'm searching for an fresh-water outboard- I'm looking at a 9.9 or 15 hp 2-cycle Johnson engine, which I understand is the same body as the 9.9. A similar engine will also work. Any suggestions as to where to find an engine that will fit? Many thanks in advance, Charles Stover
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I own an electric start 15hp Evinrude and it only weighs 75 pounds. They are very powerful and well made as I think the Johnson is the same engine. This motor will plane my 10' inflatable at 25 to 30 mph! These motors should do what you need. Chief
Tohatsu makes a 6 HP called the "Sail Pro" that has an extra long shaft and a high thrust gear ratio and propeller. That might be a much better option than a 9.9 2-stroke.
Aug 15, 2012
301
Precision 21 Newburyport MA
I forgot to ask why do you have to replace the one you have in the first place? Is it beyond repair?
Aug 3, 2012
2,542
How many of these have you gone through? These 2 strokes will last forever with rebuilds. I have a 1980's Johnson 70 that had cylinder work and carb rebuilds after 30 yrs, and it starts right up and runs great. I would love to replace it with a 4 stroke, but the rebuild is way cheaper than a newer engine.
Could you rebuild the 9.9?
Aug 3, 2012
2,542
Also, if you want fresh water outboards, look in Upstate New York. There are plenty up here. At least until they are outlawed.
