I sail my 192 in very shallow Barnegat Bay, NJ & am considering installing a small ($100) depth finder & power it with a small motorcycle battery. Has anyone done it? Where would I mount the transducer? Any info would be much appreciated. Jerry
....................... just to locate the best mounting location. Permanently mount once you find it. Use any of the material listed in the archives (plumber's putty, silicone, etc.) but DO NOT get into mineral oil, antifreeze or the other mounting insanity that lurks out there. Simplest is the best.Where would I mount the transducer?
Brian, for a regular price of about $85 (but with a "sale" price and a 20% off coupon) I paid about $55, Harbor Frieght sells a great little Deep-Cycle AGM battery, same size as those "Tractor" batteries (U-1, but deep-cycle so designated DC-1). I bought one last year for my DS II, had previously used a lead-acid DC-1, but the store that I bought that from no longer sold them. The Harbor-Frieght battery powered my VHF all season last year and with a short (about 1-2 hours) session on a charger this Spring, is good as new, your solat panel should keep it up even better. AGM (Absorbed Glass Mat) can't leak, can be mounted in almost any position (good for a sailboat I say!I have a "360 amp" (whatever that really means...) U1 sized tractor battery. I use it for LED running lights and cabin light, and occasional phone or handheld VHF charging. I keep it charged with a Batterytender 5w solar panel with built in charge controller (even low amp solar panel could overcharge a sealed lead acid battery over long periods of time.) http://www.amazon.com/Battery-Tender-021-1163-Solar-Maintainer/dp/B004Q83TGO/ It does not appear Batterytender makes the 5w panel anymore, at least they don't show it on their site, just the 10w panel: http://www.batterytender.com/Solar/
I know that the tractor battery is not a deep cycle battery, and that it won't last very long deep cycling it, but I think that with my current weekend usage scenario, I barely discharge it with the LED lighting and phone charging. If I did wear it out, it should last me 3-5 years, and at $70 from Tractor Supply, it's paid for itself. I originally got the U1 battery to make it easy to carry home for charging every so often. But I just couldn't resist having a solar panel to charge it so I don't have to take the battery home! That, and SLA batteries like to stay charged. Sitting partially discharged is not good for them. Even though I don't discharge it much at all. But, hey, it's about the toys!![]()
I couldn't get a reading when it tested with a bag full of water, then when I used plumbers putty I got a reading. Then I sanded the paint off the inside of the hull and cleaned the spot thoroughly, after which my reading worked perfectly. I have a hummingbird 100 or 150...a cheap thing my wife found on clearance.Hi, I have recently purchased a Hawkeye transducer, the type that Ward mentions. I tested out various bilge locations on my O'Day 22 last season and wasn't able to get a reading. I was going to give up and transom mount it - I'm still not in the water this season. Hawkeye suggests sanding the mounting spot on the inside of the hull. Does anyone have a suggested place and method for a puck mount transducer on the O'Day 22? Thanks!
Harbor Frieght sells thos batteries for powering electric fences with a solar panel keeping them charged, but on their web-site several customers wrote about using the battery for a small trolling motor with good results. I am lucky enough to have a nearby HF store, so I'm not sure about shipping the battery, it does have some weight (I"d say about same as your U-1 garden tractor battery).
Thanks Indy,I couldn't get a reading when it tested with a bag full of water, then when I used plumbers putty I got a reading. Then I sanded the paint off the inside of the hull and cleaned the spot thoroughly, after which my reading worked perfectly. I have a hummingbird 100 or 150...a cheap thing my wife found on clearance.
I put a mound of putty directly on the hull and mashed the transducer into it, trying to keep it as horizontal as possible. Then I built putty up around the edges of the transducer to help keep it in place. I was actually surprised it worked as well as it did after being frustrated with the bag and a previous attempt with a wax toilet ring.Thanks Indy,
Yes, I have the 100, and was using the "bag of water" method. Do you place the depth finder puck on the inside of the hull and surround it with the plumbers putty, or do you actually place the putty on surface and get the reading through the putty? I really don't want to transom mount this because of holes, and also it's after the fact if you should run into a shallow area.
Chief, I see how you could have misconstrued that, but I didn't intend to use the bag for permanent install. I couldn't get a reading with the bag and so was never really sure whether I would be able to find the right spot in the hull. The bag method is the method described in the Hummingbird instructions to find the optimal place for placement. So, I gave up and just decided to pick a spot aft of the keel, figuring it wouldn't be a big deal with plumbers putty to clean it up and try another if the first place didn't work.The water bag is NEVER used for a permanent install. It is used to find the best spot to imbed the transducer. The key is like Indysailor says; and that is, a MOUND of your stick on substance that you press your transducer down into. Push down until about 1/4" or little less is all thats left below rhe transducer. This works with the wax, putty or silicone. Just be aware that the silicone bonds firmer than the wax and putty but not as solid as resin. I have used silicone for 30+ years. Chief
Roger that Chief and thank you for the wisdom you share here.I understand Indysailor, I was just clarifying the steps in hopes of helping the ones who need it. Chief
