Single handing info please
John
I have an '86' Catalina 27, and I am relatively new to this thing. What I want to do is fix the jib lines on both sides so that I can single handedly sail the boat. I have one self tailing winch on the starboard side on top the cabin as well as one on the port side in the same place. The two winches in the cockpit are not self tailing. I am wondering if anyone can tell me how to run both the jib lines aft to the wheel so I can maybe cleat them off there and work the jib by myself. Any help will be greatly appreciated. Thanks
Steve W
swap the winches, then run the lines.
If that is too much trouble, you might install a set of winchers to convert the non-tailing winches to semi-tailing. They came on my boat and work great...a bargain at $30.00 a pair. Good Luck!
MoeMac
Single - handed
Aloha I sail my 27 single handed all the time I installed a furling jib and run the lines aft. I use cam cleats for the lines Easy for one person to handle. Good luck
Bob Camarena
Self Tending Jib
Check out the current issue of Practical Sailor. It has a good article on self-tending jib set-ups that will make your life much easier. I have what's known as a Soling rig on my C-30 which works great. We sail in the SF Bay Delta and are always tacking in narrow waterways.
Joe Ford
Here are a few tips.....
John, I single-hand about 80% of the time on my C 27. It is essential that you be able to leave the helm for short periods of time to make adjustments, get your jacket, use the head...whatever. You should have a wheel locking device to hold course temporarily. Whether you do or not, I highly recommend you install an autopilot, I wouldn't go out alone without one. On a C27 the primary winches should be close enough to the wheel to steer with one hand and release and pull in the sheets with the other. Cam-cleats will make your life easier. You don't really need to start winching (with the handle) until you get the course set, that is when you lock the wheel, insert the winch handle and trim. An autohelm with a tacking feature really makes this a breeze. I have tiller steering and often, especially when jibing, I stand with the tiller between my legs, steering with my knees, leaving both hands free to work the sheets and bring the boom across, etc. As to the halyards, raise the main while under power with the wheel locked and the boat pointed into the wind. Hank on the jib at the dock, but don't raise it till you get to the sailing area. Once there, bear off to 30 deg apparent, lock the wheel, use both hands to haul up the jib, then the winch handle to trim. Sometimes, after hanking it on at the dock, I will lash the jib to the lifeline stanchion with a slip-knot. This trip line is led aft to the cockpit. That way it stays secure on deck till I'm ready to hoist. When dropping the sails, being able to leave the helm is paramount. Since I must go forward or get on the cabin top for this, I look for a calm area inside the harbor. One more thing, know how to get back in the boat if you fall off. Good luck, plan ahead and be careful.
Joe Ford
On second thought......
John, you stated that you were new to sailing and having re-read your article I realized that you appear to be using the cabin top winches to control your jib sheets. Those smaller winches are mainly for the halyards, cunningham and reefing lines. Your jib sheets should be controlled by the PRIMARY winches. These are the large ones near the wheel. The sheets should be led through an adjustable lead block before engaging the winch. The lead block slides on the genoa track running along the outside edge of the boat. If this terminology confuses you in any way, I emphatically recommend that you hire a sailing instructor to aquaint you with your boat and the rudiments of sailing. Or at the very least, that you purchase the "Annapolis book of Seamanship" as soon as possible and read the first couple of chapters before going out on your boat again. I suggest this in a sincere and well-meaning way. Good luck.
