I'm re-wiring my simple DC wiring and can't seem to get started.
I have a 10 hp outboard electric start with it's own starter battery and a separate house battery. My house loads are fairly modest as I only have running lights, radios, and a few cabin lights. I have no need to switch the batteries together as far as I can tell. Question is: if I use 6 AWG battery cables, how do I run the positive to the positive end of the panel. there is no + bar on the panel only 16AWG leads on the positive and 16 AWG leads jumping from neg to neg. I can run the last 16 from the end of the panel to a neg bus bar then back to the neg terminal on the battery, but it seems odd to connect a 6 battery cable to the first 16 on the positive side of the panel. When I mock up the system, it works fine. I'm just leary that there will be some kind of trouble when I load the whole system. The PO had 6 16 guage wires bolted to the lug on the end of the positive main lead. These leads went to each individual switch on the panel. Looks like a mess and seemed dangerous. I think I'm making too much out of this but it seems like the panel should have a large lug on the positive side to attach the battery cable to. Any response welcome. Thanks in advance!
