Shroud and Stay lengths
Oct 27, 2011
55
O'day 25 Dauphin
I have come across a posting that shows the lengths for the various running and standing rigging measurements for the O'day 25. It mentions that the length for the standing rigging is from "pin to pin" and most people say that is with the turn buckle fully closed. Should I assume then that there is still a couple of inches from that measurement to the attachment point?
1,952
Oday Day Sailer Wareham, MA
If that was the memo from O'DAY circa 1979, listing the dimensions for all models offered at that time, then the lengths are with the turnbuckles fully closed (that is tightest rigging, since shroud/stay lengths are as short as can be). Most riggers base measurements on having the turnbuckles about 1/2 open, so I would check the difference in the turnbuckle adjustment between fully closed and 1/2 open and add that to the lengths.
This is the O'DAY 25 info from that memo:
O’DAY 25 RIGGING SPECS
(Taken from a 1979 O’DAY memo)
(All Lengths and specifications are approximate and are subject to change without notice)
Main Halyard (rope) 5/16” x 59’ (K/CB)
Jib Halyard (rope) 5/16” x 60’4” (K/CB)
Mainsheet 3/8” x 40’
Jib Sheet 3/8” x 48’ (24’ x 2)
Mainsail Outhaul ¼” x 9’
Boom Downhaul ¼” x 4’
Topping Lift (rope) ¼” x 31’ (K/CB)
¼” x 33’ (Keel)
Centerboard Pendant (need to find this)
Spinnaker Halyard 5/16” x 67’ (K/CB)
5/16” x 71’ (Keel)
Spinnaker Pole Lift 5/16” x 43’ (K/CB)
5/16” x 45’ (Keel)
Spinnaker Pole Downhaul 5/16” 30’ (K/CB)
5.16’ x 31’ (Keel)
Spinnaker Sheets 5/16” x 48’ (2)
Genoa Sheets 3/8” x 60’ (30’ x 2)
All running rigging is typically double-braid Dacron (Polyester) rope
Standing Rigging Specs.
Headstay 5/32” x 30’10” (K/CB)
5/32” x 32’10” (Keel)
Upper Shroud 5/32” x 28’9” (K/CB)
5/32” x 30’ 9” (Keel)
Lower Shroud 5/32” x 25’8 ½” (K/CB)
5/32” x 16’8” (Keel)
Backstay 5/32” x 32’8 ¼” (K/CB)
5/32” x 34’8” (Keel)
All Standing rigging is SS 1x19 type wire and lengths are with turnbuckle (where applicable) closed, from eye to eye (most riggers measure with turnbuckles half-closed, so be sure to note this and/or bring old rigging to rigger to measure for replacement)
55
O'day 25 Dauphin
Thanks Sunbird for jumping in. Yeah, that's the one I have seen floating around. I am doing my own rigging so I need to get it right. So, to be clear, lets use the headstay length noted above as an example. If I were to make the shroud to the 30' 10" noted from "eye to eye" - which includes a closed turnbuckle, I should be short by a couple of inches or so to allow for the opening of the turnbuckle to provide for tension, right? I am upgrading the turnbuckles so I know I have to allow for the difference in length between the two. For me, I suppose it would be beneficial/better to know the distance between the connection points rather than the wire lengths, then any combination of anything a person chose could be made to work.
Apr 25, 2015
282
Oday 26 Oscoda, MI
Does anybody have the specs for a 1985 26'? I am literally replacing everything in the boat this year so I might as well change all riggings etc.
