Shoutout!!
Sep 3, 2026
17
MacGregor 26S 26 Tremonton
A big shout out to everyone that has helped me so far. I’m sure there will be lots more questions upcoming. A bit of good news to share is the 5 HP Nissan 4 stroke that was supposed to have been fished out of the bottom of a lake RUNS! I had to replace the spark plug due to it getting bent in transit. It will need a new water pump impeller and new throttle cables but that was expected. Started on the second pull. The cleanup is going along fantastic. I included a picture of the aft bunk before and after.
Now I just need to get all those videos edited. Thanks again.
3,225
Beneteau 343 Slidell, LA
Nice! It appears that you sealed the boards for the bunk. Good idea; my Hunter 33.5 had unfinished plywood bunk & setee backers. They always seemed to absorb moisture. I should have sealed them all with a couple coats of sealer.
