Shore Power Problems
1
hunter 27 cedar creek
I have a 1983 Hunter 27.
the power from the dock is OK
my power cord is OK
however, when I connect to the power outlet (port side of cabin), i get no power at all.
is there a power fuse or anything in the panel under the captains table that I am missing ?
Jun 9, 2008
1,860
- -- -Bayfield
Where the cable connects to the boat is called an "Inlet" for starters and the wiring from there should run to a double pole breaker on the AC Panel. If that breaker is tripped, you won't get any juice to the rest of your loads. There normally isn't a fuse elsewhere. Otherwise I would turn the juice off at the dock, or disconnect your cord and start looking at your wiring to see if a connection came loose either by pulling out of a solderless crimped eye or spade, for example, or perhaps a soldered connection came loose, etc. Start with the inlet and then the panel.
Jun 6, 2006
6,990
There may be a breaker at the shore power inlet. Probably right next to the socket. Also if you have an inverter check if the shore power / sea power source selector switch is set correctly. If all that does not help then pull the panel and after placing one hand in your pocket, probe for power at the main AC breaker. Probes with alligator clips crimped on are handy.
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
My H280 has a breaker on the inside wall, right where the shore power inlet is. Small, vinyl-coated breaker.....
Greg
