Call them. I have no personal stake but can say as a satisfied customer that they have found what I’ve needed every time I have reached outTried SBO shop here. My boat was listed but no options were given. That sorta sucks.
If I can find someone who has a drone I'll work on it. Have to admit, c!ose hauled is a tall order for me.I was trying to find an article that talked specifically about keel depth and it's relationship to pointing ability. No luck for my quick search and brisk reads. I don't think the depth of the keel is inherently bad at pointing. A shorter keel can have more trouble presenting a decent lateral plane and more windward slippage can result, especially when heeling. A shorter keel may also have less righting moment and thus a less efficient angle causing the boat to want to come up. This can mean the rudder is angled to counter this action and gives more resistance to forward motion. These both can affect pointing ability. However, with 500 plus pounds of ballast on a wide 17' boat, I't tm guessing the Seaward is a pretty stiff little sailer.
I would like to see pictures of her under sail and close hauled.
-Will (Dragonfly)
No, that will induce heel and side slipping. Generally a flatter mainsail will point hight, increase halyard or Cunningham tension, increase outhaul tension up wind, down wind loosen everything.f I can find someone who has a drone I'll work on it. Have to admit, c!ose hauled is a tall order for me.
One other thing: I thought I'd try using a topping lift this season in an effort to raise the boom along with easing the halyard and outhaul thus creating more belly in the main. Do you think that will help with speed and pointing?
A deep fin keel develops lift which allows the boat to point higher. Short stubby keels can not develop the same amount of lift so the boat can not point as high. A second factor is the keel's chord or foil shape. Boats that point well have deep thin keels with a good foil shape. This can be accomplished in a fin keel because of its depth the weight can be spread out over a longer distance allowing for a lighter more effective keel. A short shoal draft needs to be fat and long to achieve the same righting moment and can not be shaped into an effective foil.I was trying to find an article that talked specifically about keel depth and it's relationship to pointing ability. No luck for my quick search and brisk reads. I don't think the depth of the keel is inherently bad at pointing. A shorter keel can have more trouble presenting a decent lateral plane and more windward slippage can result, especially when heeling. A shorter keel may also have less righting moment and thus a less efficient angle causing the boat to want to come up. This can mean the rudder is angled to counter this action and gives more resistance to forward motion. These both can affect pointing ability. However, with 500 plus pounds of ballast on a wide 17' boat, I'm guessing the Seaward is a pretty stiff little sailer.
I found that article, but don't have a subscription, so only read the introduction. I did find another piece of it, but it talked only about one type of keel.This article might be helpful.
How keel type affects performance - Yachting Monthly
James Jermain looks at the main keel types, their typical performance and the pros and cons of eachwww.yachtingmonthly.com
Absolutely.No, that will induce heel and side slipping. Generally a flatter mainsail will point hight, increase halyard or Cunningham tension, increase outhaul tension up wind, down wind loosen everything.
The subscription is free.I found that article, but don't have a subscription, so only read the introduction. I did find another piece of it, but it talked only about one type of keel.
I'm willing to believe what you say, though. I would like to know how the foil shape's lift specifically improves pointing. There are a few boats, the planing hulls, that point very high, yet their foil keels seem quite minimal and there is no lift effect in the runners of an ice boat. Those guys have amazing pointing abilities.
-Will (Dragonfly)
In general, don't use the topping lift while sailing, leave it loose. There are only a few oddball cases where a topping lift MIGHT help while sailing and that is only when the wind is very light, off the wind.I thought I'd try using a topping lift this season in an effort to raise the boom along with easing the halyard and outhaul thus creating more belly in the main. Do you think that will help with speed and pointing?
Dave, I think you have the apparent and true mixed up. Apparent wind angle will be lower than true due to adding the forward motion vector. The first point you made is the key, ice boats seem to point high but that is only because they are moving so fast that the apparent wind goes way forward. They don't point all that well relative to true wind.The pointing ability of ice boats is based on apparent wind. Because ice boats have very little drag, they accelerate quickly as they accelerate the apparent wind moves forward as it moves forward the boat can point higher relative the true wind while maintaining a lower angle to the apparent wind. Making up some numbers, the true wind angle might be 25° while the apparent wind angle might be 40°.
And move the traveler to windward and ease the boom to about mid-ship.No, that will induce heel and side slipping. Generally a flatter mainsail will point hight, increase halyard or Cunningham tension, increase outhaul tension up wind, down wind loosen everything.
Once again, conceptually correct, practically wrong.Dave, I think you have the apparent and true mixed up. Apparent wind angle will be lower than true due to adding the forward motion vector. The first point you made is the key, ice boats seem to point high but that is only because they are moving so fast that the apparent wind goes way forward. They don't point all that well relative to true wind.
Thanks for the link. I got the boat at an auction. It hadn't been sailed for 3 years and was stored outdoors under a tree! The mess was overwhelming. I wanted a boat that I could use to learn to sail. I didn't spend a lot on it. Dealing with the inability to point has been my biggest challenge. I took sailing lessons on a boat with a daggerboard. It handled like a dream. Not so with my boat. I'm thinking of naming it The Antichrist. So I'm looking for low cost solutions to get me through this season and maybe next. Then on to a bigger boat. Or at least one that behaves.No experience with your boat. I did own a 15 ft trailer boat for 20 years.
All boats have their limits and quirks. A new sail may give you what you seek. But a new Sail is no guarantee. I looked on line and came up with Precision Sails.
Seaward Fox 17 Cruising Mainsail
Instant pricing on Seaward Fox 17 sails. Best Prices Online. Customize your sail cloth and options online.www.precisionsailloft.com
they say they have a main sail pattern for the Seaward 17.
How did you get this boat? What do you want to do with it? If your current experience is the best the boat can do are you still committed to the boat? Committed means you want to throw money at the boat. As in a new sail as compared to cutting your expenses and directing your effort and money in a different direction.
There is no doubt that a combination of improved sails and improved skills will allow your boat to sail better and closer to the wind. However, getting to sail as close to the wind as a dinghy with a daggerboard ain't going to happen. Different designs have different sailing characteristics and a beamy 17' boat with a shoal keel will not be as fast or sail as high as centerboard and dagger boat daysailers in that size range.I'm thinking of naming it The Antichrist. So I'm looking for low cost solutions to get me through this season and maybe next. Then on to a bigger boat. Or at least one that behaves.
