Shields flex marine hose removal
May 21, 2015
6
Oday 192 Mahtomedi, MN
We have an O'Day 192. Does anyone have experience removing the drain hose (connects hull drain and cockpit drain) and/or the hose that encloses the centerboard line. It's made from Shields flex marine hose. It has wire wrapped through it and won't cut with a utility knife. We were able to remove the clamps, but that doesn't loosen up the hose.
Thanks.
Sep 23, 2009
1,477
If heat will not move it with prying, I get out the dremel tool.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
A good pair of wire cutters will snip through the wire otherwise the dremel is a good suggestion and less strenuous.
May 21, 2015
6
Thanks. We are afraid to use heat as the hose goes onto plastic fittings. We may try the dremel. It's very hard to reach it without hiring a contortionist.
