She's creaking at 40
If you really want to get the job done quickly, let's go with a chain saw and a hocky mask.
When dressing in the robes of a Surgeon, everything you pick up looks like a scalpel.
Sep 24, 2018
4,467
Catalina 30 MKIII Chicago
Before you go cutting up the deck, think about what the problem is and how to fix it (easily and cheaply)
In the spot indicated in the photo there seem to be no through deck fittings. ( no stauntion or genoa sheet track.)
That raises the question If it is core rot, where did the water enter?
gary
The boat in the pic is a bit different than mine. I do have a genoa track. I also know that one of my stantions is leaking (wet wall inside)
I doubt adding FG to the underside would help if the issue is wet core, and most likely it is.
Depending on the size of the area flexing, foot pads to spread the weight will probably help to delay gel coat cracking until to you do the proper repair.
Thank you for answering the original question! Much appreciated!
