Tim
I'm having a main sheet problem on my 88 Cat 30. I have a Harkin main sheet set up where there is a double bullet block with becket at the top (off the boom) and a triple bullet block with becket and cam at the bottom (attached to traveler). The problem is that the sheet twists over time. At present it is run through the triple first and then up to the double and so on. I can re-rig it to take the twists out but after a few days it starts to twist agian. I may be running it through the blocks in the wrong order. Any ideas or does anyone know the correct running sequence?
