The reason we burp!
Mike,The REASON you burp the PSS is that if you don't, air will remain around your shaft and seal, not cooling, lubricating water. As a result, your seal will wear to eventual failure. It's easy to do, just don't forget to do it!All Good WishesRon Hughes s/v "Best Revenge" H 40.5
