Mainsail
In this photo it looks like you clamped the PSS boot to a fiberglass tube which is the shaft log.
http://www.pbase.com/mainecruising/image/75740279
I wonder if all 310 Catalinas in that era where of similar design?
A marine mechanic installed mine while I tapped the shaft from below so I did not see the set up.
I'm going to check and see how far the PSS boot is slipped over the tube....hope it's not past the first convelope. I did replace the brass fitting with a nylon from PSS and a vent tube later.
paulj :troll:
paulj :troll:
