SF Bay Jib?
3
Catalina 27 Treasure Island
Just purchased a 1971 Cat 27 and was wondering what people in the SF Bay are using for jibs, currently there is a very well used, to where the hanks are worn most of the way through, mainsail for a J 24. I've only done one shake down cruise with the jib, but the winds were not very strong on Sunday. Not sure what the Mainsail is, but it has one batten left out of three pockets (will double check next time I'm on the boat), and is made by Hogan. Any additional info on a good mailsail would be appreciated as well.
Happy sailing!
We have a summer jib and a winter jib. Summer is an 85%, winter is 110. Anything bigger would be too much for me. Been doing this for the past 30 years on both a C25 and our C34 (about 15 years each). Our racers do with max 130% jibs. For a mainsail, you want, flat, flat, flat.
Jun 24, 2013
3
Hey, thanks Stu! I have a bizzillion (not a spelling error) questions, figuring out how to use the search function. should help solve a lot of them. Not that I'm a racer or anything, but think I'm going to stick with the hank on jibs. Thanks for the tip about a flat flat flat main. What about going out the gate and heading north suppose you would want the same. I like the idea of the J24 main as a jib, the PO says it is a 80% and I like the duribility and should be able to find a reasonably priced used replacement.
Outside the Gate is a COMPLETELY different issue. While it can be blowing 25-30 inside, it's usually less windy outside, except that depending on the weather, the seas can be what will get you. And this is true all year round, regardless of "traditional" weather models that state that (usually) during summer a big high pressure system maintains itself off the coast. Well, not this year, for example. It rained yesterday and today, which means the high dropped south allowing low pressure to move in from the north. What happens as the lows move east are two things: winds increase and because of the low the seas are built up. NOT fun sailing. We've tried to sail to the Farallones twice this past twelve months, in nice weather, and have been turned back both times because of the high seas, even when we planned on good weather based on the forecasts.
I always recommend that folks buy, read and study Kimball Livingston's Sailing the Bay, a great book that explains just about everything you need to know about sailing around here.
Our C25 had hank on jibs, the C34 has roller furling, but I still switch jibs. Even though we have a ProFurl which will allow jib reefing, I tend not to like to do it.
I don't understand the "mainsail from a J24 for a jib;" is it a jib?
Same sail selection for outside and inside. You reef the main in the Bay and pop it up if it's less windy outside.
Jun 24, 2013
3
I know how rough it can be, and get sea sick when I'm Captain of my Abalone float tube. I'm sure I'll be as cautious as you, and really watch conditions and the weather and try to head out in stellar conditions. Also have been green going around the corner at Point Reyes, headed South and North coming from Monterey. Usually use buoy PZZ540-270400- POINT ARENA TO POINT REYES TO 10 NM- for Scuba or Freediving. Going to have to start looking at PZZ500-270400- for the SF bay. If you have any other sites for the weather I'll listen.
As for the Jib, it really could just be the cut of it, since it seems to have a relatively flat foot. Next time the jib is set I'll take a picture. Thanks for the tip on the book, I'll pick up a copy.
May 29, 2013
7
Catalina 320 San Francisco
I use 90% on my Catalina 320, happy in Summer :) I will see how it goes in winter.
