Self tacker
Aug 1, 2011
3,972
Not that long ago, there was a discussion here about self tacking sails. That discussion (as so many seem to do) digressed into a somewhat non technical array of commentary about how much infrastructure would be required to support an overlapping sail.
If you have a look at the "top 7 reasons" in this link to Mr Buffet's boat (and that's Jimmy, not Warren) you'll clearly see a large shiny sail up front that looks to be attended to by a single line, and yet there's a "reason" stating that it was self tacking.
Self tacking, or self tending? (or just be quiet and let the damm topic die where it should have before?) :) Oh, and not to stir the pot any more than necessary, but if the boat is so great, why are there only 7 reasons? ha ha.
https://sailuniverse.com/2018/06/20/7-reasons-love-jimmy-buffetts-surfari-50/
11,386
The shiny sail is a Code zero. It has two sheets shown, and cannot be self-tacked (or gybed).
The genoa (really a JIB) is rolled on the furler behind it, and self-tacks on a track ring in front of the mast.
Everything said in the other discussion holds true here.
Likes: jon hansen
Gunni
Mar 16, 2010
5,937
Yeah, saying that code zero is self tacking don't make it so, and they repeat it in several places. Must be the holy grail of marketers. All the same it is an interesting boat and it could keep me from wasting away in Trawlerville! Why did they have to go and put two stinkers in the thing?
Nov 8, 2010
11,386
Indeed, its amazing how some many people (both here, in general and in the press) simply believe whatever they see written about a boat/technology and assume it's true. Look, observe, and apply what you know. Critically think.
Gunni
Mar 16, 2010
5,937
I'm not even sure you could tack that sail, it probably requires being rolled up with that furling jib solent rig. Maybe that's what they mean - you press a button and roll up the reacher, tack the boat and press the button again! :p
May 27, 2004
2,059
Why is that foresail called a "Code Zero" instead of a
'Reacher' or a 'Big Fu#%ing Jib"?
I've been away you see and, Oh well...
Gunni
Mar 16, 2010
5,937
You can call it a Code 0, or a Reacher, just don't call it a Jib. Code 0 and Reacher are the same thing. A Jib is a Jib and it is not reaching sail. The others are.
capta
Jun 4, 2009
5,100
That's about as antiseptic as any boat I've ever seen. You could use it for an operating room!
I wonder how much space the two engines and fuel tanks take up? Only someone as rich as Buffet (Warren, not Jimmy) could afford the maintenance on the engines (genset?) and all that hydraulic and electrical gear.
Likes: Meriachee
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I don't see a place to lie down for a nap. There must be a market, just not what I would consider comfy.
It is obvious that the designers have never tried to sleep in a bow berth while sailing or motoring through a choppy sea. They should consider puttting a berth further aft if this is more than a coastal/day sailer.
Nov 8, 2010
11,386
There is a fair amount to like about the boat. It's like a Sense 50 with a lifting keel. That's attractive to me.
What makes zero sense is the TWIN 80bhp diesels, driving 4 blade props. All this to get the boat to cruise under motor at HULL SPEED. Wow.
May 25, 2012
4,338
jackdaw. the twin engines are to be used fighting huge game fish. to me it's the most exciting vessel i've seen in a long time. my $0.02 :)
11,386
Trust me I like it a lot! Just don't see the need or value in the twin drive.
May 25, 2012
4,338
i got to deliver a 53' Fontaine design from newport, bermuda, antiqua. it was a fantastic sailing machine. enjoyed his creation. sailed the whole way. it was an early december run.
We shouldn't have any trouble finding him on the water when he's using his Sag Harbor place. But the lifting keel would be a necessity around here and specifically near his place in Sag. It's not that deep. Then again the boat may never see waters around here. I think the boat is cool but the lines kinda put a hurt on my eye. The interior kind of harkens a downeast schooner with the white sealing, wood accents and the combination of horizontal and vertical accents. I also like the openness. I appreciate having sprawl room. I don't think this is cruising boat really. I think it's more a daysailer and hangout boat. I don't know about the twin engines but I don't think the maintenance is going to be onerous to JB. Downtime might be 'though. People who earn great toys need for them to be ready to go on schedule. More systems = more down time.
