I am running into problems with seized screws and bolts that are set into tapped surfaces including plates on the mast, cheeks on the boom and mounting points on my radar arch.Is there a way to meove seized fasteners effectively, or should I just forget it and re-drill and re-tap? If the former, what techniques are the best and what order of "attempt" do you recommend? ThanksRon Breen
