Seaward 26RK Mast Raising
May 25, 2026
1
Seaward 26RK Columbus GA
I am brand new to sailing, but have acquired a bigger boat than I expected, with no instructions. Their is a mast raising system on the boat, but the videos on YouTube, are extremely vague about how and where to attach the side stabilizers. Does anyone know or have exact pictures of where each part attaches. The videos point out obvious stuff but when it comes to these most important aspects they just gloss over it. There is a video on the 32RK, but even that is not as detailed as I need.
pgandw
Oct 14, 2023
235
Stuart (ODay) Mariner 19 Yeopim Creek
When single handing, I use a gin pole (winch mounted on gin pole), and baby stays. I found the baby stays are essential for stabilizing the mast horizontally. Because my shrouds are aft swept, they take over as the mast gets more than half way up for any side-side sway.
I mounted strap eyes to the mast (about 6ft up on a 25ft mast), and tied some nylon 1/4" line to the eyes. The baby stays run to deck mounted blocks that are 2" forward and 2" lower than the mast tabernacle pivot pin, then run to my jib sheet jam cleats. This makes the baby stays tightest at about the 45 deg point of mast raising, which is when sway is most dangerous for my mast and tabernacle. And has the added benefit of stopping the mast pivot pin from backing out the back of the tabernacle. The baby stays are rigged before raising the mast, and removed after the mast is up.
When there are 2 to raise the mast, I save time by walking the mast up myself, and have the helper tend the jib halyard. My mast is light enough to stabilize by hand as I walk it up. Rigging and unrigging the gin pole and baby stays adds about 30 minutes to the mast raising/lowering process but is the only way I could come up with to do it safely single handed.
I engineered my system myself, learning the hard way (dropping the mast). My first gin pole broke where it connected to the mast. And my 2nd gin pole was a disaster in some crosswind without baby stays.
Fred W
Stuart (ODay) Mariner 19 Sweet P
Likes: JBP-PA
JBP-PA
Apr 29, 2022
792
Jeanneau Tonic 23 Erie, PA
I use my main halyard and spinnaker halyard as temporary side shrouds while raising the mast. I attach them athwart the mast step so they stay in tension all the way up until the actual shrouds take over.
Aug 27, 2025
18
ODay 23 Roque Bluffs
Hi Fred,
I too made a gin pole raising system that is imperfect. The biggest issue is that the gin pole, where it seats around the mast, wants to kick up and the raising line is tensioned. Scares the bejuezus outta me every time. How do I keep the gin pole—2x4 shaped to the curve of the mast from kicking off?
my second issue is that I need baby stays. Are your baby stays attached to the boat forward of the mast. Sounds like they’re aft. if they're aft, how do they hold the mast pin in the tabernacle?
any advice is appreciated.
Bev
Fred W
[/QUOTE]
Likes: LLoyd B
