Hi,
Which are the 12V power and return pins on the Seatalk-ng 6 pin connectors on the display? Say when looking at the connectors at the back of the display, moving counterclockwise from the top, starting to left of the alignment key.
I just bought a i50 displays and just want to power without the complexity of installing a network. RayMarine doesn't provide a direct connect cable with the display, though the circuit is shown in the installation manual. One of the cables they provide has a 3 pin Sea talk connector so rather than spending $100 for a starter kit, I plan to cut the 3 pin connector off and connect the 2 power wires to 12V. I just want a little outside verification that I'm applying power to the right pins.
Thanks Chris
Thanks Chris
