Need some help still in choosing a correct power windlass. Any help appreciated... Here is what we have. Spencer 44 sailboat, approx 35,000 lbs displacement. 300' of 5/16" chain to a 65 lb anchor. (currently have horizontal manual windlass). Trying to choose what electric windlass to buy, and what power requirments needed to run it... Power we have: total of 6 batteries, (3 separate banks) to include.... 1 engine battery(cheap crap-wet battery), 1 generator battery (cheap crap-wet battery), and house bank of 4 AGM's (approx 400 ah). The AGM's were about 8 years old when we got the boat, work fine for the house batteries, but don't seem to charge to rated capacity. Usually only about 12.4 or 12.5 after charging.
Boat has a West Marine battery bank isolator (blue box) that combines all three banks to allow the charger or alternator to charge all banks, but only draws from selected bank. I know the basics, but hard to decide what to buy and if I can use the batteries we have or add another battery up forward and wire it to the existing bank, or separately. (we have a good place to mount the battery up front) and our current windlass is about 10' back from the bow of the boat, nearly in line with the main mast, where the chain comes down into the locker.
I'm thinking at least a 1500 watt (12v / 125A) windlass, maybe adding an 8A4D (heavy duty DEKA) battery to run it... then just add the 6 or 8 gauge wires for charging to my current isolator? Or I would have to run the heavy wires to one of the other banks to add the battery. Also this battery is 127lbs... so that is a concern also, but we really need to weight on the right side of the boat,... It is heavy on the left too much already.
Basically trying to figure out what windlass to buy, then work on putting the pieces together after getting the beast. Thank you,, Noyrt...
