I'm going to remove some thru hulls (all below water line) and seal the holes.
1982 pearson 367.
I plan on grinding a 15:1 bevel around hole, then layering mat and cloth until the hole is filled up.
I am unsure of which resin to use, epoxy or polyester.
I know epoxy has better bonding characteristic than polyester.
i've read that polyester and epoxy curing agents cause blisters (maybe only when moisture is present?).
Which resin should be used to fill in old thru hulls on a polyester hull?
Thanks
1982 pearson 367.
Thanks
