I suggest the twist lock prevents siphons from both inlet and waste lines. Why?
The motive forces for inlet sea water and exit waste is started by the pump and can continue if siphon breakers don't work. Locking the pump stops both siphons. The high point loops prevent back flow and so do good sea cocks.
Nope....Doesn't work that way 'cuz the intake line isn't connected in any way to the discharge line. The intake pulls water to the top of the pump and pushes it into the bowl via inlet fitting at the top of the back of the bowl.--which doesn't actually start a siphon...the intake line on a below-waterline toilet just provides a path for water outside the boat to seek its own level INside the boat.) The pump pushes bowl contents out the discharge at the bottom of the pump...that does not start any siphon either. Bowl contents will continue to move through the discharge line only as long as the pump is pushing them or gravity takes over. Those two functions are totally independent of each other. You can stick a plug in the discharge fitting, and the pump will still bring in water in the wet mode...you can also close the intake seacock and the pump will still push bowl contents out. Vented loops are just air breaks, they don't prevent backflow.
I like it because once the flows stop, siphon break plugged or not, i statically secure my inflow line from continuing to fill bowl.
Sorry to burst your bubble, but you don't. The only effect that securing the pump has on the intake is to make it impossible to operate the pump, thus makingi it impossible for YOU to continue bringing in any flush water. It can't stop any flow that's already started or prevent new flow from starting. A siphon break (vented loop) can't prevent any new flow from starting either, but it CAN interrupt the flow started by priming the pump with an air break that stops it.
