Seaclear to ST1000
geehaw
May 15, 2010
231
O-day 25 shoal keel Valdez
I am wanting to hook laptop to ST 1000 autotiller. I have found one explanation on doing it but it refers to using a USB connection with a USB to DB9 adapter. MY laptop has a serial DP9 connection. I was wondering if I can use this instead of the adapter? And if so I have not had any luck in finding out how to make this COM 1 required by Seaclear. Greg
Sumner
Jan 31, 2009
5,254
If you are sure the 9 pin is serial you need to find which pins are the input, output and ground (common) or at least the output and ground and wire up a cable with the appropriate end for the computer (might not need the input with the autopilot, but you also need to get GPS position into the computer. You could use a USB GPS device on one of SeaClears other 'receive' only inputs).
Most laptops haven't had serial for a long time now.
In SeaClear you need to go to "Tools" then "Properties" then "Comm" to setup the serial ports and their rates. You will first need to find which com port the computer is using for it's serial port.
You will also need to use the "Tx/Rx 1" since that is the only one that will transmit. The other two are 'recieive NEMA' only.
I love SeaClear, but might switch to OpenCPN as not much new has happened with SeaClear and people are adding more and more to OpenCPN all of the time. The main feature that I now like is that you can click tide stations and current stations right on the chart you are viewing and get current and future tide and current info. Up till now I had to go to the handheld garmin for tide info and had no current info. There is also other new features with OpenCPN that I didn't see a couple years ago when I first looked at it.
I still like SeaClear in other ways and will probably run both into the immediate future. Good luck and I have not run an autopilot with SeaClear to this point, so take what I posted above wth that in consideration. We do have an ST4000 on the Endeavour and I do plan on using it with either SeaClear or OpenCPN in the future,
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
Sumner
Jan 31, 2009
5,254
I forgot, but OpenCPN also seems to now handle inputs and outputs for things like GPS, AIS, and autopilots a lot easier than SeaClear,
Sum
geehaw
May 15, 2010
231
Thanks Summer I will try OpenCPN and see if I like it. Just been using Seaclear so familiar with it. Well the question might become moot because I found the book on my new laptop and it is a D 15 pin monitor connection. Old eyes old brain.
Sumner
Jan 31, 2009
5,254
I like the simple straight forwardness of the SeaClear, but it looks like it isn't going anywhere and OpenCPN is. I wish I could find charts that worked with either for the Bahamas and the Sea of Cortez.
I looked at the monitor connector on my laptop and saw that it had more than 9 pins so thought maybe you did in deed have a serial port on yours. I know all about the eye deal :cry:,
Sum
Our Endeavour 37
Mac-Venture Links
[FONT=Arial, sans-serif][/FONT]
