Sea Frost Relay, Acr 7610 Replacing Battery Isolator, Altern
Aug 3, 2014
68
CATALINA, BENETEAU OCEANIS 36, 400 Grosse Ile, Mi and Fajardo, PR
Alternator D+ stud
Good Morning Maine,
I am replacing my battery isolator (.8 volt drop) with a Blue Sea 7610 ACR. The Sea Frost refrigeration relay is wired to the alternator side of the isolator. I plan to wire the relay to the D+ stud on the alternator. What do you think? Will you define the purpose of the D+. Thanks.
Nick
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
Could you mean B+? I would wire it to a 24 hour circuit with a fuse.
Feb 6, 1998
11,760
Good Morning Maine,
Nick
Can you be more specific on which relay this is driving? Is this an engine driven unit or DC? Does it have a rotating timer dial?
Aug 3, 2014
68
Re: Sea Frost Relay, Acr 7610 Replacing Battery Isolator, Al
Maine,
It is engine driven with rotating dial. Perhaps I should connect it to my ignition. Thanks.
Nick
